What To Do When My Laptop Wont Connect To Wifi And Its Solutions
Hello, how to solve my laptop wont connect to wifi notify it in stepwise to know understand about it . Thank you for the same.
Hello, below shows the solution for my laptop wont connect to wifi is as follows:
• First you have to see at the right edge screen and select the setting
• Now click on the wireless network
• Under the network part click for the Wi-Fi first click off and then turn on again for connectivity
• Now which every wifi you want to connect can be easily connect without any problem
If your laptop won’t connect to your Wi-Fi, check the credentials used to connect to the Wi-Fi network. To connect a device to a Wi-Fi network, you need to know the SSID of the Wi-Fi network. SSID stands for Service Set Identifier and is the name of the Wi-Fi network. It is a case-sensitive alphanumeric character identifier that can be up to 32 characters long that identifies a network.
Make sure the SSID you specify in your laptop is the same as the SSID of the Wi-Fi network. The casing of the characters must be the same. If this is correct, the next thing you need to check is the password used to connect to the Wi-Fi network. The passphrase or pre-shared key that secures a Wi-Fi network is case-sensitive.
You need to enter the password exactly as it is. A character in the password that uses a wrong case is already a wrong password. The encryption method used should also be the same. If the Wi-Fi network uses WPA2 encryption method, you also need to select WPA2 in your laptop. You can check what encryption method is used on the Wi-Fi network on your laptop.
The encryption method used is attached to the Wi-Fi name or SSID which is displayed in your laptop. After following these, you should be able to connect to your Wi-Fi. If you don’t know the SSID or Wi-Fi name in case it is hidden, you won’t be able to connect to the Wi-Fi network even if you know the password.
