What is a tool that performs auto correct html errors?
Hi to everyone,
I would prefer a programming language tool that will correct spellings and proper usage of html automatically and will really help in fixing errors.
There are some instances that it could not be possible but somehow I am hoping to get some information from you. I need a secure tool.
Your suggestion is very much welcome.
Answered By 0 points N/A #180961
Hello Davis,
Adobe Dreamweaver is the best software for web development. It’s very easy to code and also you can find and correct your errors. It is very expensive though. You can try it for 30 days. Download it here
You can use HTML-Kit which has a utility called Tidy. You can download trial version of HTML-Kit for 30 days. The download link . Tidy will suggest you to correct any errors in your code.
Use W3 validator tool to check errors and correct errors in your code.
Remember, for your code to be fine you have to check it thoroughly, rather than handing it over to an automated tool.
