Ava larry
10 points
Posted on - 12/13/2012
Hi guys,
What is the tool remove title window?
In that website there is what we call a title window, the text that appears at the top of a visitor's web browser when viewing a particular page.
I want to remove our company title window in the website just for now and I will think of a better title window later.
As of the moment all I want to do is delete it, can you help me?
Expecting some help, thank you.
Hi Ava,
There is no tool for deleting title. You have to do it programmatically.
Depending on the language you used to create that website you can change or delete the title.
As you didn’t mention about the source code details we cannot give the code details.
Please update with more details.
Hope this help!
Hi Ava Larry
Well you cannot delete your windows title at all.
There is no software which deletes the windows title.
But there is a way for you to hide the title of windows.
There is software named “window hide tool 2.0” for you to hide the title.
You can download it anywhere from internet.
This will help you to quickly hide the title of any window which you want by using hot keys or by using clicking an icon on the tray.
You can specify group of windows by their title text.
I hope you’ll find few good things in this solution.
Good Luck!
Johnstoon Leen
Hello Ava Larry
Hope you are fine. It’s true that there is no basic tool to remove title from your website.
But you can do it by your website designed program.
There is an option called Meta description in your website code within <Head>…</Head>.Within <head> tag you will get <title>…..</title> and there you will get the title bar which is showing every time someone visit your website. Delete the line from <title>…</title> option.
Your website coder can do this easily.
Hope this will help you.
With Thanks
Greaney Mary
