What is the top program Whois in PHP
Hi everyone.
I need a program to check domain information including when it was created and when it will expire.
What is the top program Who is in PHP that can do this?
Any help or suggestion would be much appreciated.
Thanks in advance.
Best Answer by Graham Mcnatt
Answered By 5 points N/A #141066
Hi! You can use "Check Domain Name Availability Software 7.0" you can download this for free or purchase this for full version.
This is the link where you can download this.
This software will allow you to check the availability of any domain name you like and it supports Windows Operating System. You can also you the "Domain name status reporter" to monitor any registry of all domain names and can filter all unwanted DN.
Answered By 0 points N/A #141065
 Hi Doriswneil. There is one software that can help you with your problem.
The name of the software is Domain Name Status Reporter.
It is a small but very efficient, and powerful piece of software which is monitoring the registry status of any domain name.
This software also provides the critical record creation date and registry expiration dates.
I hope this helps you with regards to your problem.
