What is the use of apple pc suite 64 bit? I have some research paper regarding apple pc suites and I was not exposed much in ios applications. There are some things that I have to learn about apple operating systems as well as the features. Tell me more about this.
Waiting for your support, thank you.
Isabela,
Maybe you are referring to the iPhone PC Suite.
The iPhone PC Suite, a data utility management software which serves as an alternative to iTunes. It allows people who have Windows computers easy access to iPhones. This allows data transfer, direct access to songs, mobile messages, call lists, photos. It is perfect for quick synch of your data and the iPhone.
Plus! This software is completely free for use.
The 64-bit is one of the versions of Windows 7 OS. It comes in 32-bit also.
You can check out this review for more information: http://www.softsea.com/review/iPhone-PC-Suite.html
Hi Isabella!
Pc Suite is manage your phone easily and very safely,
It's Back up and Import contacts, set the ringtones, themes and wallpapers and manage the system, Â also registry of the phone,
You can install and uninstall software, manage schedule.
You can manage all functions and settings on your phone,
And it's free to use.
