What is the use of desktop work plan calendar?
I need the desktop work plan calendar. But I don’t the features of desktop work plan calendar. I need the details about this desktop work plan calendar so that I will be able work on it. I am not sure about it why it is used? Can you let me know the details of it?
Answered By 0 points N/A #160132
Hello there friend,
I have looked up on the Internet and found a solution to your problem.
http://download.cnet.com/Desktop-Calendar/3000-2124_4-10365743.html , read what this site has to offer, and I will try to explain it in my words, to make it simple for you.
It`s a simple grid, also nicknamed a spider web where you can add your appointments and important notes.
It looks like a wall calendar. You can then transform notes into .txt format, add a description..
Just look on the site and you will find what you need.
Not the best tool, but this will help you if you work with it.
regards,
