What is the Use of Replication Manager
Hi Keny,
EMC Replication Manager manages replication through a centralized management console. Replication Manager simplifies your replication and puts the right data in the right place at the right time. Save time and money while increasing data protection with Replication Manager.
You can use Replication Manager for handling occasionally disconnected computers, such as using laptops and connecting computers to a Web server via a browser.
Hope this can help you.
You should use Replication Manager to manage your replica set. It has distinguished features. Replication Manager helps you set up all your replica synchronizers by creating a map, and you can monitor all replicas with your manager. Replication Manager will solve your many problems. You can use replicas to make backups, select database objects, make replicas read-only, and assign current synchronizers.
Thanks,
Max
