Hello techyv,
What is the use of safe eraser software? Can you share some important information about this matter? The company told me to clean up the Windows 7 operating system registry for they will let me install new application software next week. I have to be more ready for the installation process.
Expecting some help from you guys.
Safe Eraser is one type of softwares. These softwares allow you to clean up data in your PC securely. You can use many eraser softwares which allow you to clean up unused registries easily. Sometimes this is needed to install new softwares.
Some of the best safe eraser softwares are Wise Care 365, Tune Up Utilities etc.
Hi Amanda Mitchel,
After some time using a computer, there will be some junk files, invalid shortcuts, invalid registry, temporary internet files, temporary system files,… on your computer. You need to clean all of them to keep your computer works smoothly, and it gives you some space for your new software too.
All you need to do is choosing the best software that helps you to clean your computer safely. I give you two softwares like this: CCleaner and Glary Utilities.
You can download CCleaner here:Â http://www.piriform.com/ccleaner/download
And Glary Utilities here:Â http://www.glarysoft.com/glary-utilities/download/
Hope this helps
