Hi to everyone,
What is the use of Samsung Galaxy GSM modem? Tell me if it is possible to use Samsung galaxy as a GSM modem. I am not that expert when it comes to researching and exploring things. I need some help from you. Your suggestion will be much appreciated.
Thank you.
What is the use of Samsung Galaxy gsm modem?
Yes, it is possible to use Samsung Galaxy as a GSM modem.
You can connect it with your pc by USB or through wireless as well. Firstly you have to install the drivers for the desired application. If you don’t have the drivers for the desired application you can download it or you can purchase it from market.
Samsung Galaxy GSM modem helps you to connect your phone internet to your computer. You just need to connect your Samsung Galaxy with your computer via USB wire or Bluetooth. For this you need an application which is available on the below link:
http://drivers.softpedia.com/blog/Connect-Your-Samsung-Phone-to-a-PC-without-Kies-237352.shtml
Download this app and install it on your system. Connect your phone and run the app.
I hope it will help you.
