Hello Techyv.com!
I have here a hard drive that needs repair. The problem of this hard drive is that it has so many bad sectors in it, and I'am already tired of formatting my PC. Now I was wondering if it is advisable to repair this hard drive or would it be better to buy a new one? What is the usual hard drive repair price to start with?
What is the usual hard drive repair price?
If your hard drive has so many bad sectors and other problems then I would suggest you a best maintenance/repair software for hard drive. Download Windows Repair Tool from the given link below.
http://www.supertuneup.com/tuneup/download_com/?
You can solve your hard drive problem by using of built -in tools. I hope you may fix your problem.
The best suggestion is that you should buy a new hard drive rather than to get it repaired. You can get a good size hard drive in the range of $100-$200.
