What is a valid credit card number with data generation ?
I am trying to search for a Credit Card Generator which I will be used for my newly opened online store which is a traveling agency. This is to test the data generation so I need the best and legit ways to do this. And it should also be protected and has no issues on security. Thanks.
Answered By 0 points N/A #135521
There are web-sites that help people generate phony credit card numbers which look legit and could possibly pass off as a genuine credit cards. The fake card numbers however fail to provide a legit personal account number which technically disqualifies it from being a valid credit card. Since such unscrupulous who would wish to check out using a fake credit card do exist it's important that you confirm that the credit card is valid or use third party merchants such as Paypal to get all credit card payments at a fee.
If, however you want to brave the risks and want to process the credit card payments yourself then the online service I would recommend checking the validity of credit cards is Check Credit Card Numbers The credit card checking tool uses java code that's executed right from your browser which in effect means the web owners don't store any information on their servers.
So if you'll need to worry about security issues then you only have to worry about security on your side such as key-loggers or someone actually looking over your shoulder as you manually enter the credit card numbers on the web site, etc. NOTE: Since you're just starting out the best option is to use a third party merchant to process the payments for you. It will save you time and stress. These merchants have been in the industry long enough – trust them.
