Hello to all members here my question is related to last one please clear it too. Thanks for replying and post of solutions. How can we know what version of the .Net framework is installed on my PC? Is there any software to check this?
What version(s) of the .NET Framework are installed on my PC?
There are software's out there but you don't need software's to check any application's version installed on your computer (win XP or win 7).
All you have to do is just go to.
1. Start.
2. Control panel.
3. Click on Add or remove programs (win XP) or Programs and features (Win 7).
4. You can see the version of your .Net framework as above.
Khem Ely
You must have to know that the Version 3.0 .NET Framework is already included in Windows Server 2008 and Windows Vista and you don’t need to install it in your Windows. While in Windows 7 the Version 3.5 is included.
If you are using Windows XP or Windows server 2003 family then you can also install Version 3.5 in your operating system.
There is no requirement to install any individual software for this. You can use this solution in Window XP, Windows 7 and Windows Vista. You only have to follow these steps.
Click on start button.
Type the following in RUN and press enter.
cmd /c dir/b/ad "%systemroot%Microsoft.NETFramework" & pause.
I hope you find the best solution.
