What virus can damage hardware
Hi Guys,
Is the virus can damage hardware? Why is it my hardware right now is not working? help me.
james curt
Hi Guys,
james curt
Hi
No,the virus can never ever damage your hardware.The reason is that the computer viruses are software coded and they can only corrupt your data,including your softwares in that particular computer which is attacked by some serious virus.It may stop your software/hardware working,but that cant damage your hardware part.
Your hardware is not working due to the software not installed perfectly on your computer.For this first uninstall the driver from your machine and then reinstall the drivers of that particular software.
Secondly install the latest software of that particular hardware device,your hardware will work fine.
Thanks
