Please explain the main purpose for developing the jquery line of software. I mean why was jquery developed? Is jquery commonly used in website source codes? What are the advantages of using jquery? How is jquery meant to help the programmer design codes? In which area of code development is jquery most helpful?
points
What was the main purpose for the development of jquery?
jQuery is an advanced library for JavaScript. Since JavaScript is a powerful method to develop websites innovatively, jQuery is a powerful library for more advanced functions, methods and utilities. It is able to create advanced functions, gorgeous animations and much more, depending on the coders’ creative mind.
In order to learn jQuery, you should learn HTML, CSS and JavaScript at first. With its advanced functions, you can do more tasks without writing large codes. If more things are done by less coding, isn’t it superb?
The best part is, jQuery developers are concerned of the cross-browser platform and so, the library is acceptable by all browsers. Thus, your dynamic website will be available to all browsers, just by coding once.
There are many websites that use jQuery as their web solution. Google, Microsoft all are heavy users of jQuery, along millions of other sites.
jQuery is freely available from jQuery. Learning jQuery means better coding experience, better looking site. As a developer, you should come in handy with this tool for being a legendary programmer!
How are you?
J Query is easier to use compared to standard java script and other java script libraries. In J Query less code is needed. J Query enables you to perform flock of functions compared to other Java script libraries. It is very efficient and secured for scripting. There are a huge number of plugins are available in J Query. The J Query website has a comprehensive documentation and tutorials. J Query helps you to develop Ajax templates very easily. That is exactly it. Learn more.
Moreen Jamnelly
