What is the way to Benchmark Your PC
Benchmark is important for every computer. How to Benchmark Your PC? What is the way to Benchmark Your PC.
To properly benchmark your pc, perform the following first:
Hello UaskMe,
PC benchmarking is a process to test the computer’s performance. For doing this first of all you need some cleaning software. Run that software for cleaning registry and other temp files also. You can use winaso. Now uninstall all kind of unnecessary software from your computer and restart. Now go to task manager and see if all the unnecessary files are inactive or not. If they are inactive then ok or you have to inactive them manually. Download any Benchmarking software from online, but I suggest you to download PCmark or novabench. Those two have some really good review and I personally used PCmark. Run benchmark and compare the result in online.
Thank you,
Riley weaver
