What will happen after the deletion of System 32?
I'm currently on Windows 7 and I want to find out what actually happens after the deletion of System 32 folder in C:. Will I lose my Windows installation or anything else will happen? I'm an enthusiastic researcher so I want to find out the issues after deleting System 32 file folder.
Answered By 0 points N/A #192580
System32 is your entire system basically. It provides instructions for how to run windows. So deleting it will not help. Basically, it is an OS for Windows. Even if you just delete even a single file form it, your monitor will stop displaying things and your PC will start working slow. System32 is a dictionary that contains the core drivers and files of Windows.
Answered By 0 points N/A #192581
System 32 is a directory that contains system executables and libraries of Windows OS.It is controlling your system completely. When we setup a Windows OS system 32 folder gives all indications for running windows.In short, if you delete the system 32 folder or anything in it then you have to fall into danger. It can slow down your PC or reboot your PC again and again. So, from my opinion you should away from system 32.
