What will happen if I delete TOAD exe software from the system
I think a software TOAD.exe is creating problem in my computer. Will it create any problem if I  remove this TOAD exe software from my PC? I want to be sure about that before deletion.
Thanks
Answered By 270 points N/A #196059
Hello there  Gloriawburbage,
TOAD or toad.exe is a TOAD for Oracle belonging to a TOAD for Oracle from Quest Software Non-system process. This process has been proven that doesn't have any harmful security effects on your system. To permanently stop this process you need to uninstall "Quest Software" or "TOAD for Oracle" from your system. Note : Uninstalling applications can leave invalid registry entries, accumulating over time so you better have a good registry checker for your machine. Hope this helps.
Waall Mike
