What Will Happen if you not Update your Windows Settings?
I clicked on the " Do not Install Updates" settings on the Windows OS and other software application. What will be the effect on the Windows OS if I did not update the Windows settings? Has it a same effect if I didn't update the application software to its newer version?
Answered By 10 points N/A #194197
Windows updates are sent by Microsoft to help keep your PC safe.
Those updates consist of security updates, and some other important updates.
Windows will be automatically updated frequently unless you choose it to turn off.
It improves your system performance. PC will work faster than before and reliably.
But if you do not install those updates there is a possibility that your system may be attacked by virus or malware.
Though you can turn off these updates, but make sure you clean your PC regularly, clean the registry, scan your computer, do hard defrag, run anti virus and much more.
