What will happen when we compress the files?
I heard that we can save the space by compressing the audio song files.
If I compress the song file then what will happen.
Hi Dear,
Compression has many concepts behind this.
If we copy our file in rar or zip folder, it will also calls compression.
When we reduce the quality of file then it saves some space it is also called compression.
In the first option, when we copy our file to zip folder.
It will not reduce the quality of the files.
But if we compress the file for the 2nd purpose, then the sound quality of the file will be decreased.
This is not a good idea to compress the files to save the space.
I hope you got your answer.
Thanks
Compressors are such softwares that use their algorithm to calculate and create files into smaller size. When decompressing, they calculate the compressed file and output the main file. Thus we can use compressors to save disk space.
