Hello experts,
What is a workspace updater? I don’t know how does this workspace updater work? How does it work and the advantage and disadvantage of this update in the computer operating system. Also discuss with me the benefits of getting the workspace updater. Thank you.
Hello Danield,
A workspace updater is a utility that will help you to make changes to an existing project that has got published workspaces, for instance a change in a List drop down value or maybe a new list to be applied to all "in-flight" workspaces. You can do that by either using "Content Types" and "Site Columns".
Nicke
Hi. Danield Make,
Workspace updater actually provides an infrastructure that lets an application conveniently update the workspaces and group the different versions of the row values in different web spaces.
I hope that this will be the best definition for you.
Thanks & Regards
Gillam Janetj
