What is the world smallest laptop?
What is the world most smallest laptop and what is the characteristic of this gadget? Is it reliable for everyday use?
The world most smallest laptop is the Toshiba Libretto. It is a line of subnotebook computers that was distinguished by its combination of functionality and squeezing a full Windows PC that is almost the size of a hardback book.
The latest model that was released last year 2010 is the Tablet Libretto model, the W100. The following specifications are: Intel Pentium U5400 1.2 GHz, 2GB DDR3 RAM, 62 GB SSD, two 7-inch multi-touch TFT displays with Windows 7 Home Premium and it is 819 g with 8-cell battery.
It is reliable for everyday use since it has a unique feature wherein it replaces the keyboard with a second screen, creating a dual screen experience. It allows a user to view two pages at once, one on each screen. It could also be held vertically or horizontally, depending on your needs.
Lastly, it could be closes to prevent damaging the screen and it has a specialized cases which typically protect fragile screens.
By the way, Libretto is a user friendly that can make you feel comfortable using it.
Hi Onam Ophir,
I am glad that you posted your questions here. I hope I can help you. As what I have researched the smallest ultrabook is the Sony VAIO Q which has a 1.25" display and it weights just 3 lbs. I can be suited to your pocket. It is also packed with 1 GB AMD Radeon HD 6550M graphics. It is very unique from all other laptop. Look at the illustration it shows the specifications and features of this smallest ultarbook:
I hope the information I have given will help you.
