Hello can anyone tell me about the warped file what is wpd file and what is his purpose of using I have some wiped file and I also don't know how to open a wpd file in windows can any help me about to know the wpd file i will be very thankful to him.
What is a wpd file
Wpd file is a word processing application in a system which is owned by the core with a very high and long history of different types and multiple personal computer platform.
Here is a way to open wpd file.
1. First, you have to open a word document, Display the file menu and after that click open.
2. Here a dialog box appears, you will have to select the All file types (*.*) from the files of type drop-down list.
4. Now you have to select the WordPerfect file and click the open button.
5. Now click the file menu and click on Save As.
6. Select the word document from the save as type drop-down list and click save
What is a wpd file
.wpd is a Corel WordPerfect extension and WPD denoting word perfect document. Corel WordPerfect is outdated hence to open the extension you will need to rename your file extension from .wdp to .doc To rename it just right click on the file>rename and give it a name and add the extension .doc for example important.doc After doing that Microsoft word should be able to open the document.
AlternativelyÂ
1. Open Microsoft word-click file-openÂ
2. In the file type at the bottom of the dialog box, select the drop down menu and change it to all files (*-*)Â
3. Browse the file and click ok
 4. Word will automatically convert and open it
