Hi experts,
I want to know about the power of active security protection Norton. Norton has been a powerful tool for active security? Please tell me about it with trustful research publication.
What is your thinking about active security protection Norton?
Wassup Anthony, I believe I will be able to help you find a solution to the information that you want to find out. Norton has been a powerful action tool as you state. It makes weekly scans to your computer to determine if it has any infections of viruses, malware, spyware or other threats.
Norton also delivers superior performance with very fast scan speeds.
When doing a scan operation, it runs in the background in order not to interrupt your work in the computer.
There has been extensive tests with the AV-Test labs in Germany to reveal how it has been the head of the class.
I hope this solves your query.
Hello Anthony,
The basic function of any antivirus is to stop and remove the malicious viruses from your computer. Different packages offer different protection level. For example:
1- The free version will give you the basic security which will detect and remove viruses from your PC.
2- The paid version of the software will give you more protection which is internet security, removes spyware and malware.
Norton has been named among the best antivirus software's. You can also check out the latest features of Norton website. Depending upon your need select the package and install it on your computer.
