Hi IT EXPERT,
What's the best antivirus? Who created them? any idea?
Thanks,
jacky generosa
lee hung
75 points
What’s the best antivirus? Who created them and why?
There are many antivirus available on the market and with regards to brand that would be depending on the Operating System you gonna use. I believe that every Operating System has its design antivirus software which would be ideal on his Operating System. Did you know that the one who created the anti virus is the Operating System Manufacturer? Just like Windows product they also created their own virus design to infect their own Operating System so that the client will also buy a virus scanner after buying Operating System. They can earn a profit for this, because virus scanner are now necessity just like Operating Systems. So in terms of antivirus products i just recommend 1 the McAfee Scanner is developed by Microsoft. Try to search to the internet for the other Microsoft products. With regards on your question who develop the virus? It is obvious the one who develop the Operating Systems is the one who created,
Thanks,
Tony Stevenson
There is really no such thing as the best antivirus since the security of one's computer is the responsibility of the user and the level of security becomes depended on how careful the user is. Different antivirus programs differ only in a very minute manner, one being able to detect a certain virus signature while not being able to detect another that can be seen by another brand. No antivirus software is strong enough when paired with an idiotic user. There are a lot of companies who create these security software including McAfee, Symantec, AVG, Avast and a lot more.
