rey tucker
10 points
Posted on - 11/27/2011
Which is the best product of PLDT for CCTV do i need to get for PLDT Watcher for example i have 5 branches and i want to monitor my branch by using there programs or i will install internet connection per branch and buy CCTV camera. What's the best choice??
Thanks,
Rey Tucker
lee hung
75 points
What’s the best choice: PLDT Watcher? or to buy CCTV camera
Hi Rey,
If you avail PLDT Watcher it cost 2,000 Pesos per month right? If you connect internet just for CCTV purposes then you can only paid 999 per month, you can save 1000 per month. Some agents said if you avail plan 999 still you can't used this for CCTV because the IP address given by PLDT is dynamic IP address, CCTV needs static IP address in order to view your site, but right now CCTV manufacturers design a software that could still functioning even if your internet has a dynamic IP address, you just log into there CCTV site then you can automatically view the site you want, it has same settings as usual. So it's up to you if you like PLDT Watcher which is expensive or have an internet in your own.
Thanks,
Tony Stevenson
