What’s the best iPhone game available?
Hi guys,
Will any one help me out it's urgent. Recently I had purchased a iPhone set and I don't know anything about games. Any good suggestions.
So, tell me fast.
Regards.
Hi guys,
So, tell me fast.
Regards.
The Best Games for iPhone are following:
Angry Birds
Fruit Ninja
Rat on The Run
Street Fighter IV
Guns on Wheels
Tap Tap Revenge 3
For more information, there is a software through which you can download and install apps and games in your Apple device. That software is iTunes which can be downloaded.
If it’s your first time to use an iPhone, here’s how to install apps from the Apple App Store. First, search for the app you want to download. On your iPhone, tap “App Store” to launch the App Store app. On the next screen, tap the magnifying glass located on the bottom right corner of the screen. Next, enter your search query then tap the search button.
Now, navigate through the apps that match your search query. When you found your app, tap the game or app you want to purchase or download for free. On the next screen, if the app is free, tap “Get” or if it is a paid app, tap the price of the app. Next, put your finger on the Home button to activate the Touch ID.
