What’s the best wireless router and netcards available
Hi IT experts!
I'm going to be getting a high speed broadband service soon well with (Cox Cable). I was wondering what is the best wireless Cable Modem and wireless Router to buy? I have another question what is the best either net card to buy also? I will be hooking up to 3 computers and I really don't know anything about what's the best to buy and how to hook it all up. If anyone out there will be willing to shed a few opinions, it would help me out big time,
Thanks,
Reina888
Best Answer by lee hung
Answered By 75 points N/A #122243
With regards to the Wireless router I suggest SMC 7004VBR Barricade, this has 4 port router an ideal for the residential used. Has a print server feature and new feature of firewall compare to other brand.
Ideal router
This device has a VPN tunneling supports with traditional ISDN which has the latest features. This router is secure capable in intruder's attacks. This has a lifetime warranty.
With regards to the net cards, it is advisable to use the net cards from your Internet Service Provider (ISP).
The device from your ISP compares compatible to the other brand which has a tendency with the internet config problem, while using ISP net cards it's just simply plug and play.
Normally net cards are being package also if you want to apply internet connection.
ISP netcards
They used different brands on it like:
Siemens
Alcatel
Nokia
If you hooked on the 3 computer don't use wireless connection if you PC is just in 1 place, so you can save the wireless router cost.
Tony Stevenson
Answered By 0 points N/A #122245
Try to go to https://www.pcworld.co.uk/gbuk/index.html they have a sale on all items of Networking cables and also the routers of High speed wireless connection. The name of the router is NETGEAR N150 DGN1000 Wireless ADSL Router. It is more reliable and also have more helpful for you.
The most important thing in this that it have a complete help book with you easily do everything which create error in your PC or company. They also have 10% to 15% rebate on all items and the best of all it is free shipping.
Answered By 0 points N/A #122247
Try to buy a Netgear modem and wireless router it is good.
