What’s the difference between 1920×1080 and 1920×1200?
Asked By 7060 points N/A Posted on -
Hi Experts , Hi i have a new question. My question is What's the difference between 1920×1080 and 1920×1200?Please tell me the right answer of this question.I am waiting for your Right answer .see you later. Thank you.
Best Answer by sheena.dav
Answered By 0 points N/A #81207
Hello ,
Technically speaking there is not much difference in between 1920×1080 and 1920×1200.
· 1920×1200 resolution has 120 more pixels vertically
· Also aspect ratio for 1920×1200 is 16:10 and that for 1920×1080 is 16:9.
· But because 1920×1080 is 1080p more monitors are opting this resolution so that HD movies will be free from  black bars on top and bottom of screens.
· If you are gamer then you will realize the difference in FPS (frames per second).
· And finally 1080 resolution monitors are cheaper than 1200. 😀
So, between two of them I will recommend you to buy 1080 if you are more interested in HD movies and games but 1200 will surely give optimum resolution for gamers so set your priorities and make the choice! 🙂
Answered By 75 points N/A #81209
These could be figures standing for the screen resolution of your desktop. 1920×1200 monitor will have more pixels hence have better performance compared to 1920×1080, so you can choose which to buy.
There are some things that you might want to consider when choosing your monitor. Things like what you intend to use the monitor for. Is it for gaming or you intended to use it for watching movies or for general purposes like surfing the internet, typing your work.
If you want to use it for watching movies and playing games then I will suggest that you purchase the 1920×1080 monitor which will offer you better resolution, but for general assignments you can go for the 1920×1200 monitor.
Hope this helps.
____
Lee Hung.
Answered By 590495 points N/A #320317
The 1920 × 1080 and 1920 × 1200 are both screen sizes or screen resolutions in HD monitors. The only difference between the two resolutions is the height. They have the same length or width which is “1920” but differ in height. The first screen resolution, 1920 × 1080, has a “1080” height while the second screen resolution, 1920 × 1200, has a “1200” height.
All these numbers refer to pixels. The second screen resolution displays a much taller image than the first while displaying image in both “1920” pixels wide. To be specific:
  • 1920 × 1080 means 1920 pixels by 1080 pixels
  • 1920 × 1200 means 1920 pixels by 1200 pixels
