Surabhi
Posted on - 10/07/2011
Hello guys.
I am Surabhi. These past few days I have been thinking to buy a new gadget. But I can't decide which gadget I should buy. Is it an IPAD, APAD or laptop/netbook. Can anyone here help me how to choose the right gadget.
Thanks guys.
Surabhi
mikekay
What’s the difference of IPAD and APAD?
As you can see above, that's an 'Apad'. Apad is generally a name given to all Android slates that are made in China. The recent Apad made by Moonse supports android 2.1. The irobot Apad which runs Android 1.6 Operating System has 128 MB of RAM, a touch screen of up to 800 x 480 resolution, it also has 2 USB 2.0 ports. An Apad supports "WiFi" network connectivity. It also has an SD card slot which can support up to 32GB.
While an iPad is a product of 'Apple inc. It only runs programs and applications approved by Apple from the Apple app store. It also supports the local wireless area network (WiFi) and 3G network for some iPad models. It basically looks like an iPhone and it runs all iPhone applications in addition to it's own various applications.
jamespop
Hello Surabhi,
You will get a clear idea if you read this post attentively.
Apad is a Chinese tablet PC which is suitable for the Android operating system and it cannot run with the Apple App software but it can run software from the Android stores. It is a portable device like laptop and you can use this device for Internet, searching information, receiving and sending emails, playing video and audio even reading e-books.
There are 7 inch, 8 inch and 10.2 inch touch screen, Apads available with GPS function and Bluetooth, built in WiFi and external 3G network. Certainly it is more entertaining during your traveling time. On the other hand an iPad looks cool. So I personally prefer Apad or Laptop. But if you want high quality games and want to type faster then I suggest you to buy a laptop over a tablet anyway.
