What’s the new feature in MS Word
Collaboration and navigation is much easier for long documents. Documents can easily be accessed from Windows Mobile Set without compressing the file. Even word documents can save into a web server to access and edit it through web browser. In Word, the new artistic effects and text formatting tools make it better.
MS Word 2007 is a new and renovation of previous MS Word version. There are many features in the MS Word 2007. You can do DTP with your MS Word software. There are big differences between MENU and FEATURES. Features is where you can work unlimited. You can do your work in an organized method.
Besides you are able to do chart and graph. You can make cell and columns, accounting, statics. You have the features to connect with internet and you can fix the web cam to your computer where MS Word has been installed. New feature should be included in the future software.
