Whats wrong with my PC?
What is the problem with my PC? I installed a new window but my speakers are not producing any sound. Help me.
There might be several causes that there’s no sound in your speaker.
First of all, check that your speaker is connected to the right port. Connecting with wrong port won’t give any sound. This tutorial will be very much helpful for connecting to the right port.
If still the problem persists, you should install the right driver for your sound card. Identify your sound card, find out the right driver for your card and install it.
This Microsoft KB will help you a lot.
If the problem isn’t solved, you should contact with an expert technician for a fix.
