RamZy159
20 points
Posted on - 08/03/2011
WhatsApp  is one of the most popular messaging applications for mobile phones.
It is stated that it is designed to work on smartphones especially IPhones, Androids, Blackberry and Nokia.
But why some Sony Androids cannot install this application?
Is there any way to make WhatsApp can be installed to Sony androids?
zoowey
What’s App Messenger Application Compatibility Issue
WhatsApp Application is compatible with any Android powered device and that includes Sony Android devices. It can be downloaded and installed using the Market application provided that the Android version running on the device is version 2.1 or higher, otherwise, the Operating System should be upgraded so the Application can run.
There is also a known issue with WhatsApp's conflict with some installed third party "Task Killer" applications. Sometimes it is the reason why the application won't install on some Android devices. If you have a task killer installed, you may want to uninstall it first before installing WhatsApp. Actually there's almost no need for task killers in Android version 2.1 or higher so you may want to consider deleting the App totally, but if you really find a need for it, you can download and install it again once WhatsApp has been installed and configured properly.
