When add script to document get error message
When I add the script to document I get the following error message “Error opening release script “Alfresco Kofax Release Script". Any help would be really appreciated to resolve this error. Thanks in advance.
Error opening release script “Alfresco Kofax Release Script” for batch class “Alfresco Test” and document class “Alfresco Test Document Class."
Kofax Capture Administration
OK
Answered By 5 points N/A #171736
Hello Shaun
I may have the solution for your problem. This error may indicate that you have not copied the binaries to your Kofax Capture bin directory. Make sure you have the following files in the bin directory:
Alfresco.Kofax.Release.Core.dll
Alfresco.Kofax.Release.Core.Logging.xml
Alfresco.Kofax.Release.Core.xml
Alfresco.Kofax.Release.inf
Alfresco.Kofax.Release.WebScripts.dll
Antlr.runtime.dll
Common.Logging.dll
Jayrock.Json.dll
log4net.dll
Spring.Core.dll
Also make sure you have properly installed alfresco kofax integration. And ensure that you have entered a valid folder path in the Working Folder field on General tab.
I hope you find this information useful.
Randolph
