patty white
10 points
Posted on - 08/28/2012
My PC’s operating system is Windows 7 Home Premium (64 bit). When I attempt to install Nitro PDF Reader I receive the error message shown below. Can anyone please let me know why I am receiving this error?
Thanks in advance for your thoughts.
Nitro PDF Reader Setup
An error occurred during the installation of assembly 'Microsoft.VC80.CRT,version="8.0.50727.4053",type="win3
2",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitect
ure="x86"'. Please refer to Help and Support for more information. HRESULT:0x800708C9.
OK
When attempt to install Nitro PDF Reader receive error message
There is a problem with your windows. Try to run scan using your command prompt and paste it there “sfc /scannow” without the double quotes, Wait the process until it will finish. Check the installation again and see if it solves the problem. If still not solve, try to install service pack of windows that you are using or install VC runtime which you can found on C++ Express 2008, you can download it here https://www.visualstudio.com/.
If still not work, try to check if the program that you want to install is compatible with the operating system that you are using and make sure that you use the latest version of the software you want to install.
janine
The better solution for this is to download another version of Nitro PDF Reader which is compatible to your 64 bit Windows Home Premium. There are softwares that cannot be installed into a 64 bit Operating System. You can search in google.com or ask.com for different version of your Nitro PDF Reader. I can also recommend you another PDF reader which can be installed into different versions of Operating System. This software is called Adobe reader and this is what I am using right now.
