When can you use the app compatibility growl?
Good day!
I had a friend that knows this app compatibility growl. And he has shared it to me. But I really don't know what's the use of this app. So can anyone tell me what this app all about and how will I use this?
Thank you for answering.
Best Answer by Ray L Brown
Answered By 70 points N/A #172519
A) If the quantity of items if not huge sort the column and remove duplicates manually.
B) If there are thousands then:
1) Sort the column
2) Add a formula in a new adjacent column as follows:
B1=IF(A1=A2,"" ,A1 )
Select B1 and copy, then fill down (of past into other rows as necessary)
3) Now select column B and copy
4) Paste into a new column using the menu item "Edit > Paste Values"
Answered By 50 points N/A #172521
Hello White,
The purpose of this application is to send notifications of particular events to the user in real time. In this case the benefits of this application is the user who receives information such as completed downloads, the current music tracked title, FTF connections, etc. Growl is also a universal notification system for Windows and OS X.
