When checking the checkbox it locks the whole document
10 points
Posted on - 11/14/2011
Good day fellow! I have tried to getting the checkbox to be ticked. For this check the lock form in the ‘Developer’ tab, protecting document and editing restrictions check to ‘fill in form’. But I found that this is locking whole document and free format filed is just unusable. How can I used the checkbox correctly, one by one?
