Hi experts,
I just re-installed my Windows OS. After a couple of weeks, it showed an error message that looks like this:
My system is now normal but I am still wondering what the cause of the error is? Any answer is very much appreciated. Thanks!
When does Generic Host Process for Win32 Services encounters a problem?
Generic Host Process error occurs due to security related issue in windows files. This error only comes in windows xp SP2. Its ineed to install latest security updates from microsoft website so that such kind of errors could be ignored in future.
I think this problem is caused because your computer isn’t that healthy. You can solve this by making sure that all the programs on your computer, especially the antivirus and windows itself, are updated. This might solve the bugs in some of the programs and make sure the antivirus is well equipped to protect your computer. Also keep in mind that if you are sharing files with another computer, you might be getting these infections from them. You can know this if your computer wasn’t affected before you started sharing the files.
