When DP Finisher reached at the end of RunonceEx I got the following error message. Any Help would be greatly appreciated. Provide me the proper way to resolve this error. Thanks in advance.
LINE 0 (File "C:DPsFnshr.exe"):
timerStop($tmpTimer)
^ERROR
Error: Unknown function name.
Tamam
When DP Finisher reached at the end of RunonceEx got error message
I think what you mean by “when DP Finisher reached at the end of RunOnceEx” is when the installation was about to finish and the progress bar is at the end then the error was thrown. If that’s the case, it is possible that the error is unexpected. Try restarting your computer and run the installer again.
If there’s no problem with your installer and you meet all the requirements, the installation will push through. But if not and you see another error, there is probably something wrong with your installer or the program is not compatible with your system. But since the error was thrown by AutoIt, the error is obviously caused by the installer.
This means you have a buggy installer. It can be caused by a corrupted installer or if the program is repackaged. First, to make sure the program works on your computer, check the system requirements. Install any required software before installing DP Finisher. Because you have a buggy installer, visit the official website and download the latest version.
