When is gingerbread released for samsung mini?
I actually wanted to ask her directly to the Samsung website, onlybecause its webmaster Samsung suck, just look confused I want to ask willing to choose which category 🙁
If you want to call the call center or come, I'm embarrassed 🙂
So actually when gingerbread release for Samsung mini? The original version of the Samsung not leak.
Best Answer by shangeet
Answered By 0 points N/A #84833
Hi Beatrice Samsung is soon going to release the new Android 2.3 Gingerbread update for two of its budget smart phones series but had not given a specific time period or dead line regarding the release – Galaxy Mini and Galaxy Gio are the two one’s that will be realesed.But nothing to worry and get sad as you have an alternative option there of getting your device running on latest version of Google’s mobile OS now. But for that you have to be well equipped with the technical knowledge about its usage you can get this from smart firmware’s website by locating and finding out from any of the search engines where, once you get started and after the update, your phone will be compatible to run Android 2.3.3, which is known and renowned for delivering overall performance with battery life time improvements and enhancements. Thanks
Answered By 0 points N/A #84834
I think you have to wait for a couple of days to get the Android 2.3 Gingerbread. For instance you may only happy to get the update for two smartphones Galaxy Gio and Galaxy Mini.
I have a better option for you (for those who are bored of waiting) that you can run Google’s mobile OS but the technical knowledge is too much important here.  Because it is a leak I advise you to backup all your data to proceed. You can get the update of android 2.3.3 from this site.
Answered By 0 points N/A #84835
Extremely happier for your information and then expect you really know what a great job..thanks a lot
