When I Install Heavy Application, I Face A 0x00000f4 Error Message
What is the 0x00000f4 error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
0x00000f4 error occurs when a vital function of the system is terminated. It affects the computer function seriously. When an important process dies, then Windows go to a new state, and when adjustment happens to fix this error, then Windows does not function well, and it throws an error.
The steps to fix this error are as follows:
• Check the system.
1. Open your command prompt.
2. Now execute the written code: DISM.exe /Online /Cleanup-image /Restorehealth.
3. If Windows Update is corrupted use the following command instead: DISM.exe /Online /Cleanup-image /Restorehealth /Source:C:\RepairSource\Windows /LimitAccess.
4. At last, run “SFC /scannow” and press Enter. It will scan for corrupted files.
• Use utility software to fix the error.
1. Download Driver Easy as utility software.
2. Click on Scan Now.
3. Click on Update All to update the drivers to the latest versions.
4. Restart the system.
• Uninstall the problematic software.
If still there is a problem, then uninstall your problematic Third-Party Anti-Virus software.
• Ensure that all the hardware and software must function well.
The screenshot of the 0x00000f4 error is shown below:
Notifications
