When i setup Windows i face problem.
When I enter CD in DVD writer to setup windows, it does not setup. The computer start automatically with previous version.
What is the problem?
Hello Subrato,
It is a problem in your boot menu. Check out your boot menu and see what is given as your first choice.
This problem causes when the first choice is the hard drive.
Then whenever you try to set up your windows, it will re-open the previous version. You have to change your first choice.
Make this CD ROM now.
Then a new set up will be done.
Thank you for your question.
Hello Subrato,
The problem is your case is improper selection of boot devices, when we start our system the BIOS start to process the sequence from the drive which is selected as a 1st priority boot device in your case it is the hard drive, so the existing windows starts automatically.
To change the Boot Device priority you need to Press DEL key at to enter BIOS Setup.
Then from the BOOT menu you can select your DVD writer as First Booth Device.
Make Sure after installing windows you again change it to your hard drive.
Shwanj Whudson
You can resolve your problem by following the instructions:
