When I Start My Computer From Sleep Or Hibernation, I Face A 0x00000fe Error Message
What is the 0x00000fe error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
0x00000fe error is a critical error displayed when Windows shut down due to a kernel problem to prevent further damage to the computer. The main cause for the error is the system corruption. When the system starts from the hibernation or sleep mode, then basically error message shows on the screen.
The steps to fix the error are as follows:
• Scan the system.
1. Go to the start menu.
2. Open Microsoft Security Essentials.
3. Check the Full option and click on Scan Now option.
4. Now close the tab and restart the system.
• Check the internal storage of your device.
• Update the Nvidia drivers/ Windows driver
1. Download Driver Easy as a driver update software.
2. Click on Scan Now.
3. Click on Update All to update the drivers to the latest versions.
4. Restart the system.
• Locate the corrupted file and terminate it.
• Deselect the USB Selective Suspend Settings.
• Use Tech utility tools to fix the error.
The screenshot of the 0x00000fe error is shown below:
