When I try to load MPEG2 video an error message appears
20 points
Posted on - 07/06/2013
When I try to load MPEG2video, an error message appears. I checked all the settings but they are default as it is. How can I remove this error? Can you provide me the solution? I really need your help. Thanks.
Error Setting video
ffmpegsource factory: FFmpegsource video provider: Failed to index: Can’t create parser
avisynth factory: AviSynth error: FFVideoSource: Can’t create parser
OK
