When i uninstall the program it reappears after log in
Hello everybody
I am here with a problem in windows 7 OS. When i  UNINSTALL the program it uninstall. Then i restart my computer then that uninstalled program reappear on control panel. FILES AND FOLDER DELETED FROM DESKTOP ALSO REAPPEARS. Any solution please.
Best Answer by Bett Salvandor
Answered By 0 points N/A #162241
Check whether any virus or malware in your computer. If you uninstall a program via Programs & Features and yet that program still runs, then it would appear your system is fatally 'damaged' in some way.
I would ensure data is backed up to external, then restore the Laptop to factory condition.
Having done so allow windows update to run for Important Updates ONLY – this may require several restarts, then install any driver updates from that laptop maker.
Answered By 0 points N/A #162240
Hello Nickbhojan,
I am using windows 7 os, Now i am giving some suggestion on it follow the direction and i think your problem will be solved,
Step 1: Did you uninstalled the program from control panel if not then uninstall the program from control panel then i think it will not appear again and about the folder and files go to the manager and delete from there.
Step 2: Check your virus protection is it updated if yes then scan for virus sometimes virus make such type of problem.
Step 3: If the problem still there then you can setup your windows again and check for the virus.
Thanks
