During my trial of updating the system, I encountered an error windows update error code 8e5e0147 and since then I was not able to download or install any of the updates. Help me.
When I Was Downloading Updates On My System, I Got The Error Windows Update Error Code 8e5e0147. Unable To Update System Now.
The error is linked to the windows update. It is because of the changed settings or some software that might be interfering in the updates. The following methods will be useful in solving this,
- Disabling the firewall and any other antivirus or software.
- Downloading the Microsoft fix it and running it in aggressive mode, after that rebooting the system. A fair warning that it will delete the update history but will keep the list of the updates installed.
One of the above-mentioned solutions will work for you. Thanks
If this problem appears constantly whenever you install a Windows update, try using the utility called Microsoft Easy Fix. Once downloaded, run the program in default mode and then after that in “Aggressive” mode. Once it is finished, it will prompt you to restart your computer. Restart your computer then try installing the Windows Update again. See if it works.
You may also try running the System File Checker tool that scans your computer for incorrect protected system files and then replacing them with correct ones. To use the tool, click “Start”, “All Programs”, “Accessories” then right-click “Command Prompt” and select “Run as administrator”. In the command prompt window, type without quotes “sfc /scannow” then hit Enter. After this, restart your computer and try installing the Windows update again.
See if it works.
