When making replica using lotus notes error file does not exist
I’m making such replica using the Lotus Notes 4.5 Replicator. But whenever I submit it on the database, such error occurred. “File does not exist” is the prompt message always popping. What should I do to make a successful replica?
Answered By 10 points N/A #114501
Larry,
There can be multiple reasons for this error to pop up.
In order to resolve, you have to check the following first:
·         The back up is done on a removable media? If yes, then the media is no more recognized
·         The Backup is done on a network drive? If yes, check the network connections
·         The Actual file has been moved or deleted. Search the file
·         The error may occur and a blank dialog may appear in cases where the Personal Address Book is not named Names.nsf and/or is not located in the Data directory.
·         The error may occur If bookmark.nsf, cache.ndk, or desktop6.ndk does not exist. If so then make sure their .NTF equivalents exist in the Data directory.
RGDS
Rogers
