Could not connect to the remote desktop gateway server is temporarily unavailable; I can’t understand why did this occur and don’t even know how to solve this. Please tell me what to do? I need to solve this as soon as possible.
When Remote Desktop Gateway Server Is Temporarily Unavailable What Should Be Done?
To solve this problem, you will have to follow the states steps accordingly
Initiate administrative tools, internet information, decide application pools and select Default App Pool and choose advanced settings.
To catch the remote web access working once more you require altering the Enable 32-Bit Applications setting to ‘Disabled’ over again. With the help of this method, I hope your problem is easily solved.
