When Trying To Connect To Wi-Fi On Laptop, How Do It?
I have been trying to connect to my Wi-Fi network from the past half hour and only message I get is unable to connect to this network. Please help me to connect to Wi-Fi on laptop.
To connect to Wi-Fi on your laptop you need to make sure that the laptop is recognising the correct password of the Wi-Fi network. To make sure you have typed in correct password you have to connect to the modem using Ethernet cable and type in the address 192.168.1.1 using your browser and type in the password in the wireless section of the page you will get to know your Wi-Fi password or change it. Then try to connect to the same Wi-Fi with the new password.
