When using Java,I receive a warning “Form Loaded With Errors”
Hi guys,
The work I do in Java requires the services of NetBeans. However, when I try using it, I receive the error shown below. I have paste the error message below, “Warning – Form Loaded With Errors" Error occurred when loading the form data. It is not recommended to use this form now in editable mode – data that could not be loaded would be lost after saving the form.
Please go through the reported errors, try to fix them if possible, and open the form again. If you choose to open the form as View Only may see which beans are missing. ” I do not understand why this error keeps on showing up.
Does anyone have an idea?
