Why am I getting this error message even I am not using any illegal tool neither virus on my PC.
Whenever I try to play RaiderZ or Aimp3 to listen some music the following error occurred. What should I do now?
I want some resolution from an expert. Any help would be really appreciated. Thanks in advance.
RaiderZ Error
A security error has occurred.
Error Code=110
Error Msg=GameMon Already Exist
File may has been altered by Virus or Hacking tool. Please inspect by Vaccine softwares.
Whenever try to play RaiderZ or Aimp3 to listen music error occurred
Hi Steven,
The error can occur because the game has collisions with other programs or game is not properly closed.
There are multiple solutions to resolve the error.
Solution 1: Game not properly closed.
1) Close all the running applications in the system
2) Reboot the system
3) After rebooting the system, the game will work properly
Solution 2: Remove the files through task manager
1) Right click on task bar, Select 'Task Manager' window
2) In the 'Windows Task Manager', select the Processes tab
3) Select the unnecessary processes in the window and delete them
4) Select the 'End Process' tab, the selected process will be deleted
5) Restart the system
